It is currently Wed Jun 25, 2025 9:44 am
PostPosted: Sun May 07, 2006 10:06 am
Can any of you guys inform me of the success or failure of the 6 pin 12 string bridge design , where each pin holds two strings in a shared hole.
I figure it would save a lot of bridge mass and having twelve holes drilled through this important area .
It would also enable a smaller bridge footprint and bridge patch area . It would be less glue area than other 12 string bridges though. Would this be a concern?
Regards KiwiCraig
CRAIG LAWRENCE of AUSTRALIA
PostPosted: Mon May 08, 2006 12:36 am
I have done this over-sized a Martin style bridge by about 20% and used over sized unsloted pins. I over-sized the bridge to add glued surface area to account for the extra string pull. All worked quite well, but I have to say it is a bit of a pain to string up but I guess no more tha any 12 string.
PostPosted: Tue May 09, 2006 9:47 am
     bump
